Biyahero
Feb 13, 2021Apprentice
MK63-100NAS
In reviewing the user manual for the MK63-100NAS (well actually it downloads the manual for the MK62_UM_EN) I see that it says: On your computer or WiFi device, find and select the WiFi network. ...
antinode
Feb 14, 2021Guru
> [...] His 2.4 Ghz network continued to be named Rivers-TWC and his 5G
> network continued to reset itslelf to the name NETGEAR-5G which I
> suppose is the default.
Firmware bug? With "Smart Connect" enabled, the router should be
using the same SSID for both radios, so you should not be able to choose
a different one for the 5GHz radio. But I'd expect it to display that
same SSID for both radios, too.
My first question would be whether the wrong SSID is being used, or
only displayed on the web page. (Wrong either way, of course.)
> Bugs (hardware and firmware) in Netgear routers have been reported
> here more than once. (By me, among others.)
I rest my case.
> [...] "Techicolor" and a Hiron - Model En2251.
"Technicolor"? "Hitron"? I've heard of a Hitron CGNM-2250, which is
a "Gateway" (modem+router), but, I'd guess, would have a modem-only
mode. Having an accurate model number can help when seeking info.
https://us.hitrontech.com/support-only/cgnm-2250-cable-modem-router/
> [...] I WILL have one modem only device in my upcoming installation
> and one router, the MK63. [...]
Ok.
> [...] What I am hoping to do is to configure the MK63 to use the IP
> range of "10.0.1.*" rather then the apparent default of "192.168.1.*"
> Would you expect that when I set up the MK63 I would an opportunity to
> make this choice.
Visit http://netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual (ay least). Read. Look
for "Change the LAN TCP/IP settings". (My D7000[v1] is set to use
"10.0.0.*", for faster typing, for example.)
> Then, based on your suggestions [...]
Sounds plausible. (What could go wrong?)
> You might get more help, [...]
Because so much of this conversation relates to the meshiness of an
MK63, and not to the fundamentals of modems, routers, WAPs, and so on?
And the readership of that forum and this are disjoint?
Biyahero
Feb 19, 2021Apprentice
> I rest my case.
Good Point
> Hitron CGNM-2250 is a Combo Modem and RouterIt turns out there is a Hiron - En2251 Cable Modem.Acctually there is a whole chart at that URL of various Hiron Cable Modems,some of them having a Fixed Frequency of "Fixed 5-42" and others having"Switchable 5-85/5-204MHz, Extended Downstream up to 1.2 GHz" (which I will have to educate myself more on what that means), and the bottom two even have"2 Voice Ports + External Battery".EN2251-HSI Switchable 5-85/5-204MHz, Extended Downstream up to 1.2 GHzEN2251-RES - Fixed 5-85
The overlords claim:
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
Probably those are more advanced than Spectrum will want to give me for my anicipated 400 Gbps connection, so I'll probably end up with an ARRIS CM8200 or CM8300 which will likely be good enough.
> Ok.
I changed my mind about the MK63, and purchased an Orbi
RBK753S-100NAS yesterday to lessen the chances I will be disappointed.>> [...] What I am hoping to do is to configure the MK63 to use the IP
> >make this choice.
Hahaha! Right what could go wrong! Well I did look for documentation as you suggested and got the user manual for the MK63, and it does seem to let you change those settings ... now I will look for the Orbi RBK753S-100NAS Manual.
Actually though, now have decided to replace my TIme Capsule/Router (which Apple advises is nearing the end of it's service life) with a Western Digital My Cloud Network Attached Storage and use that with Time Machine to maintain reliabiliy of my backups and eliminate the IP addressing and double nat issue.
Thanks antinode I will try to find an appropriate forum for the Orbi device, but I seemingly am having a hard time finding things here ... when I try to get back to these forums I mostly get a Access Denied of Can't Reach that Site, or a Netgear Sales site... then miraculously all of a sudden it will come back. I'll keep trying.
Thanks for your help!
