Cotterk
Dec 08, 2024Aspirant
Re: MR90 Wired Connection Issues
I have been experiencing the same issue. I have 3 Ethernet wired devices. 2 are intermittent and is one always fine. Drivers are up to date
michaelkenward
Dec 09, 2024Guru - Experienced User
Same issue as what?
Your message seems to be disconnected from anything that went before.
Those devices are? What symptoms do you see? Do the MR90's logs show anything untoward.
Just another user with time on their hands.
Cotterk
Dec 09, 2024Aspirant
Same issues as Higgs22 in the above posts
- CotterkDec 09, 2024Aspirant
I may try that
I have 3 PCs on my network. 2 identical PCs (one has issues and one does not) Both are very near the router. The 3rd which is intermittent is 100 ft away.
The 2 identical PCs are HP desktops
The distant PC is an MSI gaming laptop
