ARockwell
Oct 14, 2026Aspirant
MS60 loops after update
After updating my MR60 and MS60 to V1.1.9.146_2.0.72 the satellites won’t finish booting up. On power it blinks white 13 times, pauses briefly, blinks 30 times, pauses, goes white for a moment, the...
- Oct 19, 2026
I let the sit for a few days and tried it again, and it booted! I paired it with the MR and it seems to be working. I power cycled it a couple of times and it comes back up.
ARockwell
Oct 15, 2026Aspirant
Thanks for the followups!
FrumpyGrandpa, yes, multiple times- reset for +30 seconds and 30-30-30. Unless there's another way to factory re-set it?
plemans, yes, hardwired on a tested cable to the MR and let it try for hours.
The MS just cycles. It came up after the update, even showed as connected in the MR admin page, but when I moved it it didn't come up. Now it only cycles- doesn't complete the boot.
Oct 16, 2026Guru - Experienced User
So it worked while hardwired in and showed connected?
Did you leave it like that for an extended period and check firmware?
If its working hardwired, I wouldn't be pushing for it to be bad. I'd be thinking there's some mismatch between firmware or backhaul.
