ITchallenged
Sep 03, 2020Aspirant
Nighthawk Mesh WiFi 6 dropping problems
I have a Nighthawk Mesh WiFi 6 system M63. It was installed about a month ago and worked very well for the first two weeks. Since then, the satelites keep dropping computers (2.4) and the single p...
knightz01
Sep 03, 2020Apprentice
First of all try rebooting your router this normally sorts out the gremlims for a while,
To check your firmware version
1) Open nighthawk app / hit top left home / settings / router settings / firmware version
OR
2) login to 192.168.1.1 or http://www.routerlogin.com or http://www.routerlogin.net
and look top left, you must be on the same wifi and not behind a vpn.
Kev
ITchallenged
Sep 04, 2020Aspirant
Many thanks for the reply. Your instructions were clear and easy to follow. The app indicates I am running firmware version V1.0.6.102.
I have been rebooting the router but if it is reducing the drops, the effect does not seem to last very long.
Your kind assistance is appreciated.
