Azcal
Aug 02, 2023Aspirant
Nighthawk MR60 and Ethernet Reset
It seems I have to reset my Ethernet adapter sometimes 4 times a day since I installed my NH MR60. The wireless system works fine other than the Ethernet reset. Have others experienced this? Thanks,...
- Aug 02, 2023
Thanks. It has been some time since I spent worked on the Nighthawk and remembering how much trouble I had setting it up, I will just continue to reset the adapter. But thank you for your fast response..
Aug 02, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does this happen with any other ethernet devices?
What brand and model# ethernet adapter or device do you have connected to the MR?
Ensure any ethernet adapter drivers are updated from the mfr of the adapter.
Try a different adapter.
Does same thing happen if connected to the MS satellite?
Azcal
- FURRYe38Aug 02, 2023Guru - Experienced User
Giving feedback to the questions presented can help us as well give you more information.
Others are not seeing this so this kind of points to a ethernet adapter issue.
Good Luck.
