Kacopers
Aug 12, 2021Tutor
Spectrum modem won't connect to mr60
My modem fried in a storm this week so spectrum gave me a new modem. This one only has a single Ethernet output. When I attempt to connect it to my mr60, the router won't recognize anything is connect...
Aug 12, 2021Guru - Experienced User
what modem do you have?
You factory reset the MR60 you said?
After the reset, did you power off the modem and the router and disconnect everything from both?
Then power on the modem first, leave it for 2 minutes, the power on the router?
Kacopers
Aug 13, 2021Tutor
I'm not sure the exact modem but yes i tried all of that. I even tried a different router and had issues with it connecting and receiving internet. I think it's a modem problem. I called spectrum for it.
- plemansAug 13, 2021Guru - Experienced User
Good call on trying the 2nd router. If 2 routers are having the same issue, it tends not to be the router.
did you get a chance to look at the model number of the modem?
