Aesoph
Jan 04, 2024Aspirant
Red LED - Nighthawk Mesh System
The LED on my main transmitter and one of the satellite transmitters is red. The troubleshooting guide states that a blinking red LED indicates firmware corruption but doesn’t say anything about solid red. How do I fix this issue?
- It turned out that my internet provider has a major outage and that was causing my issue
What model MESH system do you have?
Anything you can tell us that you've done to resolve this issue?
Can you access the routers web page at 192.168.1.1 after trying a factory reset? Press the reset button for 10 seconds then release.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
