fedmonds
Mar 31, 2023Follower
Removing ms60 satellite
How do I remove an unused satellite from my network? It shows up in red
Mar 31, 2023Guru - Experienced User
if its not powered on, usually you log in through the browser and click on disconnect/delete (not sure what its called exactly) in the attached devices page
- CrimpOnMar 31, 2023Guru - Experienced User
Yes, I would start on page 103 of the user manual:
https://www.downloads.netgear.com/files/GDC/MK62/MK62_UM_EN.pdf
