MinkaHarry
Jan 16, 2022Aspirant
Rental property - separate system from Home - how do I manage both with the app
I bought two MR60 — Nighthawk Mesh WiFi 6 Router systems. One for my residence and one for our rental house. Can I switch between the systems on the Nighthawk app? I want to be able to change the...
Jan 16, 2022Guru - Experienced User
Yes you can have both connected to the Nighthawk app. You'll need to be connected to either system prior to launching the mobile app.
- MinkaHarryJan 16, 2022Aspirant
I have the first system completely set up in the app. How do I add a second? I've looked around and it isn't intuitive to me.
- FURRYe38Jan 16, 2022Guru - Experienced User
Set up the 2nd system like you did the first one.
I presume you'll be setting this up at the other guest location?
