ic_
Jul 28, 2022Aspirant
Roku and Epson printer will only connect to guest network
I just purchased and setup Nighthawk AX1800 M63S. Computers and mobile devices connect fine to the home network but Roku and my Epson printer return password errors for the home network but they con...
Jul 29, 2022Guru - Experienced User
What modem/gateway do you have from xfinity?
do you have any special characters or spaces in the ssid/password? If so, remove them. I've seen the roku's have issues with some of them.
in terms of the printer, did you get it to connect to the regular network or is it still connected to guest?
Are your computers (if on windows) connections set to private or public?
You might check with the printer manufacturer as well.
