mercat68
Jan 21, 2024Aspirant
Router admin IP changed from 192.168.0.1 to 10.0.0.1
About a week ago, I found that the admin panel for this MESH system had changed from the original 192 address to 10.0.0.1 (on its own). Is this normal behavior? Thanks.
- Jan 21, 2024
It is a sign that you may have a modem that is also a router as your Internet connection.
What modem do you have as an Internet connection?
During the setup phase the router, your MR60, looks for local network connections as it tries to setup its own IP address on the network.
By default, the new router wants to use 192.168.1.1 as its local IP address. (192.168.0.1 is the address that many modem/routers go for.) If it finds another router it will go for something else, 10.0.0.1 is a regular fallback.
So, yes, it is normal behaviour, but it is a bad idea. You can end up with network issues.
What is Double NAT? | Answer | NETGEAR Support
The usual advice is to see if you can put the modem into bridge (modem only) mode. Your router will then be happy to use 192.168.1.1.
If the network is running without any problems you can just live with it, but you never know what might happen in future. One recent visitor to this place found that they had unknowingly created a double NAT network. Their printer could talk to the modem/router, but not the main router. So the printer didn't work on the network until they unravelled the conflicting IP addresses.
mercat68
Thanks. This is the access point they use: https://mikrotik.com/product/RB941-2nD-TC
michaelkenward
Jan 21, 2024Guru - Experienced User
Neat little box.
I can see no manual that has details about using bridge mode. But you may find something if you dive into the entrails of what they call the OS.
One thought, have you ever tried plugging the Internet cable into your MR60 rather than their router?
- mercat68Jan 21, 2024Aspirant
Hmm. I’lll ask them about that. I’ve never tried it directly, but I think that’s because they set it up this way when they installed it and I never questioned it. I’ll check and let you know.
- michaelkenwardJan 21, 2024Guru - Experienced User
You will need to find out what details they put into the Internet Setup slot in the MR60.
There aren't that many things to play with.
But it all works as expected, maybe best left alone. ISPs hate it when people muck about on their networks.
- mercat68Jan 22, 2024Aspirant
Just to close the loop on this, the ISP had taken their access point out of bridge mode during the recent troubleshooting. I asked them to restore bridge mode, which they did, and I did a complete reset of the Netgear system to get it back on 192.168.1.1. All working fine now. I asked about bypassing their access point and going directly to my router. They said I could do that but it would leave them blind (i.e., they would have no way to diagnose/troubleshoot problems). So, I'll leave things as-is. Appreciate all the help here.
