Siouke
Jul 30, 2022Aspirant
Router drops connection
I've got a mesh router mr60 with 2 satellites and one router things were fine originally but now I experience a extreme lag spikes bordering on disconnection frequent enough to ask for help I've confirmed with my ISP and it's not them the connection to the modem is stable and never showed a single lag spike and when I used my other nighthawk router it didn't drop either so is there some setting that could be causing these disruptions? for my pc I am wired into one of the satellites in a room separate from the router.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.the router I am using is MR60 — Nighthawk Mesh WiFi 6 Router I've tried factory resetting it and setting everything up again but the problem still came back, I've tried changing channels also elevating the router to help with coverage even changing some settings like mu-mimo , implicit beamforming, I love the speed I get on this and things were fine until 2 months ago is there anything anyone can think of to help?
