boojiboy71
Mar 29, 2022Aspirant
Router hiccups?
My Nighthawk Tri-Band WiFi 6 Mesh Router(MR80) seems to be having internal hiccup problems. Sonos will disconnect, the security cameras will disconnect, the Alexis throughout the house will disconnec...
ReasonableAp
Jun 10, 2022Aspirant
I have the exact same issue. Internet drops for 10 seconds and everything (Alexa, Netflix, etc) scrambles to reconnect. Sometimes I need to reboot router for connection to restart. Firmware installed on router and satellites is V1.1.6.14. I’m thinking of resetting to factory settings. Any ideas would be welcomed.
- boojiboy71Jun 11, 2022Aspirant
Ultimately, the only thing that helped me was the factory reset. With the mesh system I have learned to reboot the router while only having the 1st satellite powered up. I give it plenty of time to connect to that satellite, and then I plug in the 2nd satellite so that they are sequenced away I want them.
I've also found that my Sonos system devices will take whatever IP they want, despite some of my other devices being on a static IP. Sonos technical support confirmed this, it has something to do with Sonos devices not understanding a tri-band set up in a mesh system.
