msglenn2581
Feb 04, 2022Follower
Router keeps rebooting - Nighthawk MR60 Wifi 6 Mesh
I have had the Nighthawk MR60 router and MS60 Satellite for about a year now. Product name Nighthawk AX1800 Mesh Wi-Fi 6 System (2-Pack), Model MK62-100NAS. The firmware is updated and current(v1.1.6...
Feb 04, 2022Guru - Experienced User
What is working before last FW update?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
darkavich
Aug 17, 2022Tutor
I am having the exact same problem. I see it when I stream youtube or other service. I think this equipment just can't hand the traffic. Di you get a resolution to your problem or did you replace your system.
Thanks,
-Steve
