mikey59
Jun 15, 2024Guide
Samsung TVs suddenly have lost WiFi connections & won't reconnect!
I can write the same detailed content that I have posted to a Samsung forum, if needed, but basically my 2 not so smart Samsung TVs have lost their WiFi connections & cannot reconnect! I have several...
mikey59
Jun 15, 2024Guide
I have the MR70 router & an MS70 satellite.
I have rebooted everything, in order, when I first noticed the problem & the Samsung TV Plus wouldn't work, as the TVs aren't connected to WiFI, I do have Apple TV boxes right under each of the TVs & they have no problems connecting.
Everything else in the house is working with no issues. I was starting to wonder if there was any issues with 2.4 GHz vs 5 GHz, that I might need to set up a separate 2.4 or 5 GHz network & force the TVs to connect to that.
michaelkenward
Jun 15, 2024Guru - Experienced User
This suggests that faffing around with your network isn't just pointless, but could be dangerous. You could break an otherwise fine network.
Setting up "smart" TVs, especially Samsung TVs, seems to be a painful process. Go back to the TV. Go through it network setup process.
The TV doesn't care about 2.4GHz or 5GHz. If it can't see 5GHz – most TVs don't need it or support it – the setup process won't see it.
Look for the network that the TV does find and connect to that.
If possible, and if the TV supports it, use a wired (LAN) connection. You could even consider using Powerline Ethernet to create a fake wired network that uses your mains network to connect the TV. No need to mess around with SSIDs and wifi passwords.
- mikey59Jun 16, 2024Guide
Aside from the fact that everything worked fine for the past year or so, I find a couple of things rather puzzling.
That the BR TV will actually see my wireless network during the process of trying to connect to it & my satellite is in the living room, directly under that TV, but that one doesn't detect any wireless networks!
I've wanted to have both TVs, along with Apple TV boxes all hard wired, just haven't wanted to spend the money to do it.- michaelkenwardJun 16, 2024Guru - Experienced User
I'm lost? BR TV? What is "that TV"? What does not detect any wireless networks?
I've wanted to have both TVs, along with Apple TV boxes all hard wired, just haven't wanted to spend the money to do it.Dumb switches cost next to nothing. <£$€20 for five ports.
- mikey59Jun 17, 2024Guide
Not sure how to answer inline as you did on your last post, so here goes.
BR TV is the TV in the bedroom. When trying to reconnect the BR TV will at least see my WiFi network, but doesn't connect.
"that TV" that's not detecting any WiFi networks is the TV in the Living Room. I found this puzzling, as my satellite is sitting directly under that TV, making me think that would be getting the strongest WiFi signal of either of the TVs.
Yes, I know small 5 port switches are dirt cheap, but my internet connection comes into the house in another room & the wife would hit the ceiling if I just started running cables across the floor, throughout the house. I'd need a couple of network drops behind each of the TVs, that would cost about $150 each, going up through the walls, across the attic, etc.
UPDATE: With all that being said, I was able to download the latest firmware update for the living room TV (the one that wasn't even seeing the WiFi) & after the update, it saw my network, connected to it with no problem & is working fine.
