kiwicurve
Nov 13, 2020Initiate
satellite disconnecting ms60
I purchased the Nighthawk mesh wifi 6 satellite ms60 from Costco in July. It was working great up unil now. The two satellite's are not syncing to the router anymore. I've tried to synce them and hit...
Christian_R
Nov 19, 2020NETGEAR Employee Retired
Hello kiwicurve,
May you hold down on the reset button using a pin for 15+ seconds. After doing so you will need to run through the setup assistant again using the Nighthawk app. During this time I would also recommend reinstalling the Nighthawk app.
Christian
