JoeFromSD
Oct 12, 2024Aspirant
Satellite Light Is Solid White
Folks, I have two satellites plus the main MR60 unit, and one has a white light now. Tried unplugging it a couple times but it stays white. Is there anything else I can try before getting a new satel...
michaelkenward
Oct 12, 2024Guru - Experienced User
JoeFromSD wrote:
Folks, I have two satellites plus the main MR60 unit, and one has a white light now. Tried unplugging it a couple times but it stays white. Is there anything else I can try before getting a new satellite?
Replacement satellites may be hard to find.
Lots of things you could investigate.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual The router and satellite do not sync
Tried swapping the satellites?
Has something changed to break the second one?
Have you tried to reset the wonky satellite?
Does the dodgy satellite show up on the network? Can you access it with a web browser and the graphical user interface (GUI)?
Just another user with time on their hands.
JoeFromSD
Oct 15, 2024Aspirant
OK I tried to reset it by the little hole in the back, but whatever is inside didn't move at all when I stuck the pin in there, and the white light stayed on. Shouldn't it depress when I push on it?
how do I access it with a web browser?
- michaelkenwardOct 15, 2024Guru - Experienced User
It is an almost imperceptible click. The best weapon, if you don't have one of those bits of metal that come as a SIM release tool with mobile phones, is the end of a straightened paper-clip.
The best option is with a wired connection to a PC.
One problem is that the satellite will not have an obvious IP address.
If you plug the MS60 into the MR60, the satellite should show as an Attached Device. That will show you its IP address. Enter that into a browser and see what happens. The login details should be the same as the router.
Check that the dodgy satellite has the same firmware as the one that works.
- JoeFromSDOct 20, 2024Aspirant
OK I found a new satellite on ebay and it's arriving tomorrow.
will I need to set it up / pair it whatever, or just plug it in?
- JoeFromSDOct 24, 2024Aspirant
The new satellite doesn't work either. Is 60' + too far, between the two satellites for this MK60 system? Maybe that's the problem?
