n8lbv
Apr 20, 2023Tutor
Satellite MS60 SYNC button and reset
I have 3 pack that includes a router/AP and two satellites. What exactly is the purpose of the reset and SYNC buttons if they are not needed? I have tried EVERY form of factory reset on the sat...
Apr 20, 2023Guru - Experienced User
Mostly troubleshooting problems if needed.
Seems like the MS are coded to the MR as I notice my MS auto sync with out any intervention, even after a reset.
Not sure if they are intended to not be syned. If you don't need them or need less MS connected, just don't connect them.
