NPRao's avatar
NPRao
satellites are not broadcasting the 2GHz
Hi, I have a Netgear Router MR60 with 2 satellites. I noticed that the 2 satellites are broadcasting the 5GHz but not the 2GHz. This is causing issues with the smart door lock and the Garage smar...
  • michaelkenward's avatar
    Nov 19, 2023
    NPRao wrote:
    Hi,
    I noticed that the 2 satellites are broadcasting the 5GHz but not the 2GHz. This is causing issues with the smart door lock and the Garage smart controller not getting the signal strength even if the satellite was placed in the living room.
    What tells you that the satellites are not broadcasting 2.4 GHz?
    The screenshot you post just tells you that the satellites are talking to each other, and the router, at 5 Ghz.
    By design, your MK63 system is "smart" and uses the same SSID for 2.4 GHz and 5 GHz. It is then down to the wifi clients to connect to the most suitable band. If you have 2.4 GHz devices they can't see 5 GHz.
    Look at the rest of the Connected Devices list to see the devices connecting to the MK63.
