Famous8
Jan 09, 2022Aspirant
Satellites not showing up in Nighthawk App
Hi. We setup our Netgear Nighthawk MK63S Mesh yesterday and I have a few questions/problems. First of all, the two satellites show up in the web UI, but not in the Nighthawk App. I believe the sa...
Jan 09, 2022Guru - Experienced User
I've seen several reports of satellites not showing up in the app for both orbi and MK systems.
If they're showing up in the browser, I wouldn't worry about it. I'd wait on an app update.
In terms of speeds, its very variable to what device you're testing on, if you're connecting to the 2.4ghz or 5ghz, and whether you're connecting to the satellite or the router. Add in distance and interferece and its tough to say without more specifics as to how you're testing.
There's a lot of varibles that impact speeds. You could get from 40mbps to 400mbps depending on those variables.
- Famous8Jan 09, 2022Aspirant
Thanks for the help
