Famous8
Jan 09, 2022Aspirant
Satellites not showing up in Nighthawk App
Hi. We setup our Netgear Nighthawk MK63S Mesh yesterday and I have a few questions/problems. First of all, the two satellites show up in the web UI, but not in the Nighthawk App. I believe the sa...
Jan 10, 2022Guru - Experienced User
So the MS are not seen under Network Map tile on the Nighthawk app? Your pic doesn't show the Network Map tile or after you select the Network Tile app. My orbi satellites appear always under Network Map for my systems in the Orbi app.
First of all, the two satellites show up in the web UI, but not in the Nighthawk App. I believe the satellites were already paired together since they all started working when plugged in for the first time but in the app there are 0 satellites.
Second, what are average speeds I should be getting with 15 devices connected and a gigabit internet plan. (For Wifi 5 and Wifi 6 devices)
p.s Firmware is V1.0.6.116_2.0.54 and a screenshot of the app is attached below
Thanks in advance
