oldmanbill
Mar 07, 2023Aspirant
saving the configuration
as a person who as written software since 1975, I do not see any logical explanation for a company like Netgear to refuse to provide information regarding one of their features of their product. When...
oldmanbill
Nighthawk Tri-Band WiFi 6 Mesh Router (MR80)
and I have 3 satellites - Nighthawk Tri-band Mesh WiFi 6 Add-on Satellite (MS80)
- FURRYe38Mar 07, 2023Guru - Experienced User
What FW version do you have loaded on the MK system?
What browser are you using to manage the MR and save off and re-load the backup config file from the PC?
So after a FR, then reloading the backup file, the wifi SSID names are not changing to what you had configured or DHCP IP address reservations not being put back in place? More details would be helpful here.
Due to security concerns I presume that's come about over past 20 years, router mfrs have started to encrypt backup files and core FW files to keep the system running safe and out of prying nefarious people. So don't look for anything readable or viewable by home users. Though I would and do expect the backup file to work for user. If its not working then would need to troubleshoot this and if we cant narrow it down or resolve it here, then we'll need to get you to NG support and let them know.
- oldmanbillMar 07, 2023Aspirant
My only request is for a list of data elements that are backed up. I don't need to know the order they are backed up. I don't need to know how they are encrypted. I have no desire to attempt to parse out the various data elements in the file. I only want to know what is really being backed up. And I don't need to know about any hidden data elements (elements that I have no control over). I just want a document that lists each data element that I can modify, that will be restored from the back up file. This way, as I change my configuration, I will know what I need to write down myself, and what will be restored programmatically. For example, the names of the routers. I had named them Offcie, MainFloor and Downstairs. Now they are just satellite-3, -1 and -2. So that appears to be a missing element.
Possible that's not a supported save element or, there is a problem that it is supposed to be and it's not working.
I'll do some checking on this.
NG isn't forthcoming on questions like this so not sure if they will respond with any feedback. I'll see what I can get.
