cpthk
Dec 14, 2023Aspirant
Separate network with conflict channel
I need to separate the 2.5ghz and the 6ghz since I have some devices/printers that have trouble connecting when both bands share the same SSID. Since the MK83 does not support separating the SSIDs of...
Dec 14, 2023Guru - Experienced User
I presume you mean separate 2.4Ghz and 5Ghz? The MK80 series doesn't support 6Ghz. The 90 series does.
I believe the customize network doesn't allow for use of different channels. 2.4Ghz should be on channels 1 thru 11 and 5Ghz should be on 36 thru 48. Separate SSID names will be using same channels.
