Adk518's avatar
Adk518
Setting up MK63s
I will be setting up this mesh network and will be running ethernet to each access point. The router will need a ethernet switch as more than one device will be connected to it. The ethernet switch w...
  • plemans's avatar
    Jun 01, 2022
    It won't matter with only 2 satellites. You could do it either way and get the same performance. The reason is the gigabit connection is the limiting factor.
    If you haven't ran the cable though, I'd run it all back to a central location. Tends to be easier for management/troubleshooting.
