cb73
Aug 21, 2021Guide
Significant slowdown over time
MK83 (Nighthawk Mesh Wifi 6 with two satellites) - couldn't find this in the pulldown list My system works great - much of the time. Every 1-3 days, my devices on units have significant degradation...
- Aug 30, 2021
cb73
Aug 25, 2021Guide
So I took the Frontier FiOS modem/router out of the equation. I don't use their cable, so I didn't need it. Double NAT is gone according to Tracert. WIll have to wait a couple of days to see if it solved the issue. If not, I will try turning off satellites. Thanks!
Aug 25, 2021Guru - Experienced User
- cb73Aug 27, 2021Guide
It's been two full days, and no slowdown yet. I'll give it the weekend and if it's still working, I will accept this as a solution.
THANKS!
- FURRYe38Aug 30, 2021Guru - Experienced User
- cb73Aug 30, 2021Guide
THANKS!!!! 5 days of no slowdowns. Well Done!!!!
- FURRYe38Aug 31, 2021Guru - Experienced User
Good to hear.
Enjoy.
