Svtex830
Apr 04, 2023Tutor
Since I updated the MR60 firmware in January 2023
Since I updated the MR60 firmware in January 2023, I have had three different times where devices started dropping from the router. Not being very knowledgeable about these matters but able to follow...
Apr 05, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How was the system updated? Manually or using the Nighthawk app?
Did you first update the MS then the MR lastly?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I've not seen any issues with current version of FW loaded. Factory reset and setup from scratch with mine.
- Svtex830Apr 05, 2023Tutor
Thank you for the response. I read many of your posts on other reads while researching the issue and followed all the steps you, and others, recommended. None worked until I reinstalled the old firmware and then - poof - like magic, everything was good again - no fiddling with settings, no having to have a computing degree. Just simple. This highlights my issue - a firmware update should be simple. It should not require someone to spend hours researching and trying different things. If it's that hard, then something is wrong. Appreciate all the advice you've given me and others! Here's hoping the next firmware update doesn't require a visit to this forum.
- michaelkenwardApr 06, 2023Guru - Experienced User
That's how it works 99% of the time.
Every now and then – and a bit too often recently – rogue firmware escapes through quality control and dumps people in the mire.
When there is new firmware, it can be a good idea to wait and see if people report problems. If so, wait for a fix.
Experienced users also like to control what happens by doing a manual update:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
It should not require someone to spend hours researching and trying different things.Something tells me that you will be just fine in future. You are now a member of the "been there, done that" crew.
You might also like to try this:
- Svtex830Apr 06, 2023Tutor
Thank you for the support!
- FURRYe38Apr 06, 2023Guru - Experienced User
Next time, please give feedback to the questions presented as there could be other factors that are causing problems.
I for one have not seen any issues with this current version of FW with my MK63. Works great for me.
Good Luck.
