sseebart
Sep 01, 2023Aspirant
Slow speeds require daily reboots
I am seeing noticeably slow internet speeds every morning. Web pages on a computer hard wired to a satellite stutter and lag. Speed tests typically report downloads about 6-7Mbps, uploads slightly fa...
michaelkenward
Sep 01, 2023Guru - Experienced User
sseebart wrote:
The router reports that the firmware is up to date, version V1.1.7.12_3.1.108. This is a Nighthawk Tri-band mesh router with 2 satellites: AX3600 (Mk83), hardware version MR80.
Never trust what the router check tells you.
MR80 / MS80 Firmware Version 1.1.7.14 - NETGEAR Support
This might help:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
