sseebart
Sep 01, 2023Aspirant
Slow speeds require daily reboots
I am seeing noticeably slow internet speeds every morning. Web pages on a computer hard wired to a satellite stutter and lag. Speed tests typically report downloads about 6-7Mbps, uploads slightly fa...
Sep 01, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.
You can try a FW update as well:
sseebart
Looks like a Docsis 3.1, model ET2251 provided by Spectrum, built about 2 years ago. In testing, rebooting the modem has not helped with the speed issue.
Yes, it's a very short CAT6 cable
About 2400sf, but stretched out
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between MR and MS
Close to 30 feet, perhaps a bit less.
4 @ 2.4G
44 @ 5G
I assume these are the default settings, as I haven't changed them
I can see 3-4 weak wifi signals, depending on where I am on the property.
Try disabling the following and see: Armor, Smart Parental Controls or Circle, Traffic Meter.
None of these were/are enabled.
I downloaded the update, but can't apply it until my wife finishes her workday.
- FURRYe38Sep 01, 2023Guru - Experienced User
sseebart wrote:
Looks like a Docsis 3.1, model ET2251 provided by Spectrum, built about 2 years ago. In testing, rebooting the modem has not helped with the speed issue. Be sure to power OFF the modem and MR for one minute. Rebooting doesn't have same effect.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Yes, it's a very short CAT6 cable
For this size of home, the MR and one MS would be enough. Lets turn OFF one MS and observe.
4 @ 2.4G
44 @ 5G
Lets try channel 1 and 40 or 11 and 48.
Ok, try this after the system is not being used. Be sure to update the MS first then MR lastly.
