KaraBond
Oct 26, 2022Tutor
Slow wireless speed MR60
Hi, I am looking for some help as I am getting really slow wireless speeds from my MR60 mesh wifi. We are in the UK we have OFNL fibre broadband provided by Ashford, up to 900mbps. We the...
- Oct 28, 2022
KaraBond wrote:
Wired to the router I get:
Ok so we know wired is GOOD.
I have 27 devices connected wirelessly at the minute, that is made up of a mixture of:
multiple iPhones & MacBooks (5GHz), a PC (5GHz), several Apple HomePods (5GHz), Ring security devices (2.4 GHz), tvs (5 GHz), washing machine (2.5GHz), 3 sky boxes (satellite tv).
We have 1 MS, however almost everything is showing as connected to the MR, anything connected to the satellite is on 2.4 GHz.
Wired: Philips hue bridge, Tado bridge, ring bridge, sky master box.
Are there any specific wifi settings do you want?
2.4GHz channel is set to auto, 5GHz is set to 44, and its using WPA2-Personal security.
Try channel 1 and 40 on the MR.
I don't understand this question: Any Wifi Neighbors near by? If so, how many?
Do you have home neighbors near by with wifi signals?
- our sky boxes have their own wifi network, otherwise there are no other wifi networks in the area. What happens if you turn these sky boxes and all bridged OFF? I'd turn off all wireless devices and test with just one Iphone or pad with the MR and see if speeds are still low.
Oct 26, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
Be sure that when your near the MS, to disable the wifi radio on your mobile device for 5 seconds then back ON, so that the device connects to the MS and wasn't still connected to the MR. Some devices will not disconnect from the farther signal thus giving you a false speed result.
KaraBond
Oct 28, 2022Tutor
Current Firmware: V1.1.6.122
Modem Mfr: Icotera
Moden Model: i5205-02
All of the cables are CAT6.
Our home is just under 2k sq ft, I honestly don't know the distance, but they are at opposite sides of the house.
We have tried disconnecting from the wifi and reconnecting when near the satellites and we are not seeing any speed improvement.
- mnzs-blenOct 28, 2022Aspirant
Firstly there’s a firmware update available and latest version as of now is V1.1.7.132.
Please update in a order to update the MS 🛰️ first and lastly the MR 📡
Once firmware update is done, I would suggest, please move the setting in MR60 to work in AP mode..
Advanced tab: Advanced setup>WirelessAP>Enable AP Mode
Choose IP Address: Get dynamically from existing router
Click ‘apply’ bottom right.
Let me know how it goes.
All the way from 🇮🇳- KaraBondOct 28, 2022Tutor
Thanks for the info, I was checking and it was saying no firmware update available but I manually updated them.
I made the additional change you suggested and it never reconnected, I ended up having to reset the router back to factory settings and then setting it up again.
- FURRYe38Oct 28, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
