KaraBond
Oct 26, 2022Tutor
Slow wireless speed MR60
Hi, I am looking for some help as I am getting really slow wireless speeds from my MR60 mesh wifi. We are in the UK we have OFNL fibre broadband provided by Ashford, up to 900mbps. We the...
- Oct 28, 2022
KaraBond wrote:
Wired to the router I get:
Ok so we know wired is GOOD.
I have 27 devices connected wirelessly at the minute, that is made up of a mixture of:
multiple iPhones & MacBooks (5GHz), a PC (5GHz), several Apple HomePods (5GHz), Ring security devices (2.4 GHz), tvs (5 GHz), washing machine (2.5GHz), 3 sky boxes (satellite tv).
We have 1 MS, however almost everything is showing as connected to the MR, anything connected to the satellite is on 2.4 GHz.
Wired: Philips hue bridge, Tado bridge, ring bridge, sky master box.
Are there any specific wifi settings do you want?
2.4GHz channel is set to auto, 5GHz is set to 44, and its using WPA2-Personal security.
Try channel 1 and 40 on the MR.
I don't understand this question: Any Wifi Neighbors near by? If so, how many?
Do you have home neighbors near by with wifi signals?
- our sky boxes have their own wifi network, otherwise there are no other wifi networks in the area. What happens if you turn these sky boxes and all bridged OFF? I'd turn off all wireless devices and test with just one Iphone or pad with the MR and see if speeds are still low.
KaraBond
Oct 30, 2022Tutor
Thanks for the all the help both 😀
Oct 31, 2022Guru - Experienced User
Enjoy. 📡
