mmoorhead
May 23, 2022Aspirant
Sonos roam compatability
My sonos roam will not connect with my MR60 mesh system. I see someone else had the same problem, solved it but used too complicated abbreviations. I cannot understand the fisx, nor where to go on my...
mmoorhead
Have sonos ROAM. Name of the speaker sold by Sonos. https://www.sonos.com/en-us/shop/roam
Dont know what you mean by firmware and what MR means
My router is a Nighthawk Mesh WIFI 6 router MR60 purchased at Costco
Modem is a supplied by Internet supplier Spectrum
Problem is getting SONOS Roam connected to the Sonos app so it can be used with the rest of my sonos system
- followed directions and it showed up temporarily on my system list, but showed "disabled", Sonos says to turn off and turn on device, then it disappeared
- I did a factory reset on the SONOS Roam and that did not fix it
Thanks in advance for your help!
May 23, 2022Guru - Experienced User
Dont know what you mean by firmware---when you log into the MR60, you can find the firmware either in the app or through the browser. and what MR means---MR is the MR60.
Modem is a supplied by Internet supplier Spectrum---which one is it?
---sonos devices are notorious for not working well with mesh systems. I think the MR60 just added compatibility for separating out the networks for the 2.4ghz and the 5ghz. You might try that and make sure the phone is on the 2.4ghz for setup.
