Kaherdin
Apr 04, 2023Guide
Stand alone AP - MS60 satellite
Stand alone? Can the MS60 or the MR60 work as stand alone access wired points for another router? All help appreciated!
- Apr 05, 2023
Kaherdin wrote:
Yeah, the MR60 I already use as a AP in conjunction with the MS60.
But, can the MS60 alone act as an AP with a wired connection to a router?
michaelkenward
Apr 05, 2023Guru - Experienced User
Kaherdin wrote:
Stand alone?
The MR60 has AP mode.
Visit the support pages:
Support | NETGEAR
Check the section in the manual
Set up the router as a WiFi access point
Kaherdin
Apr 05, 2023Guide
- michaelkenwardApr 05, 2023Guru - Experienced User
You asked:
I answered that and explained where to look for the details.
I think not. The manual says nothing on that front.
- plemansApr 05, 2023Guru - Experienced User
No. The MS60 needs the MR60 to connect back to.
