Fredo48
May 15, 2023Aspirant
Testing wifi speed of an AX1800 satellite
Just purchased AX1800, 2 pack. Is there a way to test the speed of the satellite? The satellite is on our second floor almost directly above the router (obviously separated by the ceiling/floor). When...
michaelkenward
May 15, 2023Guru - Experienced User
Two pack of what? Netgear has about a dozen AX1800s in the catalogue.
AX1800 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
MK60? RAXXXX? WAXXXX? Orbi?
- plemansMay 15, 2023Guru - Experienced User
If its got an ethernet port (unsure without a model), you can hardwire a pc/laptop into it and check its speeds.
The dual band systems are going to be slower than the tribands and potentially even just a single router solution because they don't have a dedicated backhaul. they'll have better coverage but it miight not be as fast when in closer proximity to the router.
- Fredo48May 15, 2023AspirantMK62
The MK62 is one of the most basic mesh systems. The router will have quite a bit better speeds than the satellite will because its a dual band system.
You can read a few reviews on it to compare router vs satellites speeds. I'm preferential to dongknows reviews.
https://dongknows.com/netgear-mk63-nighthawk-review/
