Fredo48
May 15, 2023Aspirant
Testing wifi speed of an AX1800 satellite
Just purchased AX1800, 2 pack. Is there a way to test the speed of the satellite? The satellite is on our second floor almost directly above the router (obviously separated by the ceiling/floor). When...
Fredo48
MK62
May 15, 2023Guru - Experienced User
The MK62 is one of the most basic mesh systems. The router will have quite a bit better speeds than the satellite will because its a dual band system.
You can read a few reviews on it to compare router vs satellites speeds. I'm preferential to dongknows reviews.
https://dongknows.com/netgear-mk63-nighthawk-review/
