bmcguigan21
Oct 06, 2020Follower
Transition to Mesh Network
Hi all, Recently I purchased the NETGEAR AC1750 Dual-Band Wi-Fi 5 Router as well as the NETGEAR - 16 x 4 DOCSIS 3.0 Cable Modem for my 3 story house. After the purchase, I realized I was stuck to...
schumaku
Oct 11, 2020Guru - Experienced User
Brian,
Both wireless extenders and Mesh systems with a wireless backhaul suffer from the same physical limitations caused by the building substance itself typically.
Best advise is always adding CAT6A cabling or better from a central point e.g. near to the Internet access/cable modem/fiber point for the vertical and or longer distance horizontal coverage. At these cables you can add add wireless acess points (e.g Netgear WAC5xx or WAX6xx) to provide wireless access in these areas of the house. No need to be mis-guided by the all wireless Mesh marketing - this might work on some light constructions, but not in decent or older buildings.
Regards
-Kurt
