MR60Nighthawkus
Jan 10, 2024Aspirant
Unable to locate routers wifi
MR60 — Nighthawk Mesh WiFi 6 Router I have been using my mesh system with no issue for over a year now. The other night we had a massive storm, unsure if the storm is related, since then the internet...
MR60Nighthawkus
Jan 11, 2024Aspirant
Hi again. I tried again just now but unfortunately the router name is still not appearing in the wifi list. Only the guest version. I've also tried pressing the reset button but that also has not helped.
Is there anything else I can try?
Jan 12, 2024Guru - Experienced User
Last resort that you can try is a 30-30-30 reset on the MR to see if this might bring back the main wifi signal. If this fails, then you'll need to get in contact with NG support to see if you have any RMA options.
There are used MK60 series on amazon for fairly cheap if that's an option to look at if there is no RMA option for you.
