MoePa
May 11, 2023Guide
Unable to sync ms60 satellite to mr60
I bought a Netgear Nighthawk MR60 router with a satellite from South Africa, but I couldn't find a local store selling the satellite. After contacting Netgear, they assured me that purchasing a satel...
- May 12, 2023
Eureka, I have successfully synced everything and would like to share my experience to help others. Firstly, I reset the MR60 router and changed the Wi-Fi SSID and password to the Alien SSID and password, which can be found on the label at the bottom of the Alien satellite. However, I faced an issue where the original satellite (that came with my initial setup) could not be added. To fix this, I changed the SSID and password to the label located on the MR60, and then I was able to add the original satellite using the app. For the second step, I made sure that the Alien satellite was left on. Additionally, I turned off Armor. So, the trick is to change the MR60 SSID to match the labels on the satellites and add each one individually.
michaelkenward
May 11, 2023Guru - Experienced User
Netgear insists that you use a mobile app to set up these Mesh systems.
If you look careful;ly at the browser graphical user interface (GUI) you should see an option to set it up with a browser.
If you haven't done that already, I'd try it. The app can't handle anything out of the ordinary.
- FURRYe38May 11, 2023Guru - Experienced User
If you scroll down the page on the MRs 1st page, you'll see a link for if you don't have a mobile device.
You don't have to set up the MR and MR using the NH app. Web browser is supported.
- MoePaMay 11, 2023Guide
Thank you for your suggestion. Although the web interface indicates successful synchronization with the satellite when I use the web interface method, the light on the Netgear device remains amber, and when I check the network map, it shows that the satellite is not connected.
