guitarman3001
Nov 21, 2021Star
Updated to FW 1.1.6.122. Satellites now report no connected devices, and more issues. WTF?
Netgear MK63 system. FW just updated to 1.1.6.122. Sorry for my frustration but this mesh system is the biggest POS I've ever encountered. I updated the firmware because my Roku android app wou...
guitarman3001
Nov 21, 2021Star
And the fun continues.... Now in the Nighthawk app the router shows only 3 connected devices (I have about 25), and the satellites continue to show no devices connected. However, Device Manager shows 23 devices connected. This is ridiculous. The app shows they're not connected to the router or any of the satellites.....but Device Manager shows they are connected. This is some kind of magic box!! The devices are magically connected to my wifi network without being connected to either the router or the satellites!
Netgear seems to have done something far beyond our current technological capability! Internet access for devices that are not connected to any access point! Magic!!
Every single firmware update these guys put out breaks something that wasn't broken before while not fixing any of the things that were actually broken.
- FURRYe38Nov 23, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
Please try a factory reset and setup from scratch with the MR and MS. Be sure you updated the MS first then MR lastly.- mattdelucaNov 26, 2021Guide
Shouldn't have to factory reset everytime a fireware update is done, especially if you have customised your settings.
I have an issue, though only nit picking, since updating to 122, the GUI is showing my satelites as connected wired where they are actually connected wirelessly but still works ok. I haven't actually noticed within the app if it showing devices connected to the satelites or not. - guitarman3001Nov 26, 2021Star
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last update?
Please try a factory reset and setup from scratch with the MR and MS. Be sure you updated the MS first then MR lastly.No. Why in the world would I need to rebuild my whole network just to install a firmware update? I have a bunch of devices on my network and not all of them will automatically reconnect to a new network, even with the same SSID and password. I would have to factory reset a bunch of other devices. I'm a network admin for a living. I don't want to spend my personal time fixing problems caused by crappy products, I do enough of that at work, difference being that I get paid for that. Netgear doesn't pay me to troubleshoot their crappy products. I paid THEM for something that is supposed to work. They should be the ones fixing this garbage. Instead they have that 90 day support BS that is entirely useless.
A basic household router that needs to be factory reset every time a firmware update is released is a crap product. Sorry, before I factory reset it I'd rather replace it with one of the Google mesh systems that don't have to be factory reset every time an update is released. I had one in my previous house and it worked great. I bought the Nighthawk because I moved into a bigger place and needed more coverage. I've had nothing but problems with it since day one.
- FURRYe38Nov 26, 2021Guru - Experienced User
A factory reset is needed to check to ensure things are cleared out when problems happen. Been known to fix things a well. Also having a back up configuration file saved also saves time if resets are needed. Factory reset are a valid troubleshooting step. Been around fo a long time.
Up to you though.IF you had problems from day one, you should have either contacted NG support or returned the system.
Good luck.
