JLRRLJ
Aug 16, 2021Aspirant
Updates Via Nighthawk App
I am trying to update my MR60 system via the Nighthawk app on my phone. It reports the router is up to date, even though it is two versions behind. I have been trying for over a month. I will have physical access to perform the updates in about a month.
Seems pretty poor update management, when they don't publish the updates to the App.
I recommend you post in the Nighthawk app forum regarding this:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
I recommend that if you want to update and have the means to, manually download the FW files and update the satellites first then router lastly using a wired PC and web browser.
orIf your system IS working, don't fix it. :smileywink:
- JLRRLJAspirantIt's a security update, so it's working don't fix it doesn't cut it.
