SunLion
Sep 02, 2022Aspirant
URGENT! MR60 Power Supply Fail - Making LOUD buzzing / hissing sound. Still under hardware warranty
Hi, The power adapter to my MR60 is failing. It's making a terrible LOUD hissing/buzzing sound - plugged directly into the wall. Have tried other outlets in house, same problem. This feels ve...
SunLion
Hi FURRYe38 , thanks for your quick response. Unfortunately, the way Netgear has structured their support gives me the only option to post on this forum.
Sep 02, 2022Guru - Experienced User
- SunLionSep 02, 2022Aspirant
FURRYe38 Amazing, thanks so much for the suggestion. I'll PM them now. Appreciate it!
- FURRYe38Sep 02, 2022Guru - Experienced User
Send them your information and they should be able to go from there.
- wcalifasSep 02, 2022Prodigy
That sound coming from your power supply is most likely a capacitor going bad. Most of the time they don't catch fire, as it keeps going bad your router will have issues like slowing down your internet to disconnecting you until you replace the power supply.
