OfirM
Aug 10, 2022Aspirant
Use MK63 Nighthawk purchased in USA IN EUROPE
Hello, I leave in Europe and while i am on vacation in USA i wanted to buy Nighthawk MK63 AX1800 model. My question is if it will be suitable in Europe since the input written on the 3 adapters in ...
michaelkenward
Aug 11, 2022Guru - Experienced User
As I said, this is old and there is no guarantee that you can get it to work now.
Solved: WNDR3700v2 (N600) - Can't change wifi region - NETGEAR Communities
Since that appeared, Netgear may have closed this backdoor into the router.
I've region changed through telnet as well but my understanding was it was removed from the stock firmware.
Not sure as I don't have a MK63 system to test it with. I'd be hesitant to buy it without knowing for sure it works or is enabled so you can change it.
