lostgear
Feb 02, 2023Star
VLAN Tagging on MK62 on Access Point Mode + Easy Mesh
I want to create 2 SSIDs using the MK62 (or other Easy Mesh compliant Netgear routers) and tag then to a VLAN (802.1q) so that my switch can segregate the two SSIDs as separate networks. Does the MK...
- Feb 02, 2023
Not as far as I'm aware.
None of the consumer devices support vlan tagging for anything other than IPTV setups.
Feb 02, 2023Guru - Experienced User
