1 Reply
  • schumaku's avatar
    schumaku
    Neither the Nighthawk Mesh MR60/MS60 nor the similar Orbi RBR10/RBS10 have provisions for wall or ceiling mounting.
    From the antenna internals, the ceiling mount would lead to about the similar horizontal coverage. The wall mount might change the primary coverage slightly to a vertical pane.
    Air flow bottom-up (standard orientation) or bottom down (inverted ceiling mount) should be similar.
    No official Netgear view fwiw.
