PaoloPe's avatar
PaoloPe
Guide
Dec 29, 2021
WAN link instability MR60 / MK63 with firmware V1.1.6.122
Hello, I noticed a concrete instability of the internet connection with the recent firmware version V1.1.6.122 in my Nighthawk MR60 and satellites MS60 (MK63). The MR60 router is cascaded to a ISP'...
  • plemans's avatar
    Dec 29, 2021
    Have you tried correcting the double nat issue?
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
