davidbai
Feb 23, 2024Follower
Want to extend an MR60 Network (Mesh WiFi 6 Router (MR60))
I have had an MR60 with 3 MS60 satellites connected by ethernet as access points for the past 3 years. Gives great coverage but I now want to extend the ethernet and add at least 2 more satellites. W...
- Feb 23, 2024
You can only use the MS60 satellites with that version.
But luckily you can pickup whole renewed kits for cheaper than buying the satellites.
The recommendation is only 3 satellites but you're hardwired, it should be fine.
How many satellites can I add to a Nighthawk Mesh WiFi system? - NETGEAR Support
michaelkenward
Feb 23, 2024Guru - Experienced User
