jomonugget
Sep 17, 2021Aspirant
We need better documentation on the set up of VLAN's on the MR60 Nighthawk Mesh Router
I know how to configure VLAN's on Cisco Switches and their documentation is very helpful but, why is there literally about 2 pages worth of useless instructions on the set up of VLAN's for the MR60 N...
- Sep 17, 2021
https://www.downloads.netgear.com/files/GDC/MK62/MK62_UM_EN.pdf
"Set up a bridge for a port group or VLAN tag
group
Some devices, such as an IPTV, cannot function behind the router’s network address
translation (NAT) service or firewall. Based on what your Internet service provider (ISP)
requires, for the device to connect to the ISP’s network directly, you can enable the
bridge between the device and the router’s Internet port or add new VLAN tag groups
to the bridge.
Note: If your ISP provides instructions for how to set up a bridge for IPTV and Internet
service, follow those instruction."I presume is is a WAN side VLAN feature only. I don't think VLAN configurations are supported on the LAN side. You'd need a managed switch with VLAN support to do what your asking.
Sep 17, 2021Guru - Experienced User
group
to the bridge.
