istrebitjel
Jun 20, 2023Follower
What's the difference between an MK70 and a MK63
Hello, I helped a friend set up his #MK70 router with the two satellites. Seemed like a nice system Now I found a good price on an #MK63 -100NAR, however, after a lot of searching, I have not be...
- Jun 21, 2023
both are dual band systems but the MK70 system supports 160hz wide channels versus the MK60 is only 80hz wide.
Meaning the 70 series is a little faster.
If I had to choose, I'd look at the MK80 series as its a triband with the dedicated backaul.
i'm a fan of the dedicated backhaul.
Jun 21, 2023Guru - Experienced User
