vanrina's avatar
vanrina
Follower
Jul 24, 2023
Wifi Mesh 6 connects to internet but will not broadcast to connected devices.
We recently had a power outage and upon performing a factory reset and implementing the previous settings I had prior to power outage, I can not longer connect to internet via WiFi connection.  I have verified that the modem is still pushing internet with a direct connection, however when I plug into the base station of my Nighthawk Mesh and attempt to connect to the internet, it connects but without internet.  I have also attempted to change my WiFi broadcast settings to something different than what I had before and I get the same results.  Could the power outage corrupt my mesh system?
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
