Annekathrin
Mar 04, 2021Aspirant
Wifi mesh MK63 - baby monitor (cubo)
Hi, I bought a baby monitor (cubo) which has issues with the mesh network as it always searches for a better connection (I am certainly no tech expert). They require the following info the chang...
Annekathrin
Mar 07, 2021Aspirant
Hi,
Thanks for your response.
The whole house is about 150sqm and the satellite 1 and router are more than 30ft apart. Satellite 1 and 2 are probably closer than 30ft. But if I don’t put the satellite where I put it, then there is no wifi in the room at all.
Not sure about the building material, don’t think it’s concrete...
Mar 08, 2021Guru - Experienced User
certain materials block wifi better than others. And mesh systems need a certain distance for appropriate roaming to work.
