msekar
Mar 27, 2023Aspirant
Wired backhaul issue with MR60/MS60 System
I have a WiFi Mesh setup at home with 1 MR60 and 4 MS60s connected to it as shown in the attached picture. I have Wired Connections from Home Office where MR60 is located on South East corner to Fami...
- Mar 28, 2023
FURRYe38 Thank you so much. You nailed it.
The culprit was Netgear ProSafe GS110TP. I swapped it out with Netgear ProSafe GS108 and reconnected MS60s in Family Room and Living Room through wire. They started working and the other 2 MS60s are connected Wirelessly as there is no drop there. I have the home network the way I want configured.
msekar
Mar 29, 2023Aspirant
Here is the Network Map after the issue is resolved by replacing the intermediate switch. As you can see 2 MS60s are connected through wire and other 2 are connected Wirelessly. This is exactly how I wanted my home network to function. Thanks FURRYe38.
Mar 29, 2023Guru - Experienced User
Enjoy. 👍
